What is this?
Zman
Member Posts: 7,611
This might be a super simple question. The photo is a non-potable connection on a composting toilet. What is it called and how do I connect to it?
TIA
TIA
Albert Einstein
Albert Einstein
Looks like that standard flat flanged tubing with a washer and nut connection that any toilet uses but left hand thread on the nut.0
Called a bulkhead fitting, they come in all different sizes. It may be an odd thread, usually they have an NPT internal thread.
looks like the external thread is stepped, maybe for a toilet ballcock nut? Or standard lav faucet nut?Bob "hot rod" Rohr
If i'm not mistaken, it is left hand thread. That might be part of the nonpotable code.hot_rod said:Called a bulkhead fitting, they come in all different sizes. It may be an odd thread, usually they have an NPT internal thread.
looks like the external thread is stepped, maybe for a toilet ballcock nut? Or standard lav faucet nut?0 -
i missed the "hey is it threaded inside" part.0
It is not threaded on the inside but it might allow for an internal glue connection. It is the domestic connection for a large composting toilet.
https://clivusmultrum.com/
I may need to call them in the morning."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
Yes you can get glue type also. Usually the connection is made inside due to the left hand thread on the nut.Zman said:It is not threaded on the inside but it might allow for an internal glue connection. It is the domestic connection for a large composting toilet.
I may need to call them in the morning.Bob "hot rod" Rohr
- 87.2K THE MAIN WALL
- 118 Chimneys & Flues
- 113 Geothermal
- 164 Indoor-Air Quality
- 73 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
