Vitodens 100W blank screen
kingerna1
Member Posts: 4
in Gas Heating
Hello. Wondering if anyone can throw a tip or two my way on where to look on why my boiler had a blank screen. It has happened in the past and it was a fuse but i did check all fuses and they all tested good. There is power coming into the boiler but thats it? Low water cutoff is good as well. Its a vitodens 100w Thanks for any help!
Looks like there are a couple of fuses:
See page 81 of the service manual:
https://www.viessmann-us.com/content/dam/vi-brands/CA/pdfs/doc/cpk/vitodens_100-wb1bc_is.pdf/_jcr_content/renditions/original.media_file.inline.file/file.pdf8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
both fuses were checked in the beginning and both are good. Panel came of after sitting off for awhile ran for a day. now shut off and screen is blank again. Does anyone know if it could be a control panel issue? Thankjs0
ive contacted tech support. no answers. Will be getting someone out to help. Puzzling. It shut off again. Blank screen. Shut power off for an hour. After turning back on. Tries to start but then freezes. But if I turn on again without waiting for some time it stays blank0
You might need a new circuit board.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Two btu per sq ft for degree difference for a slab0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
