Boiler flames not consistent
rikmonteiro
Member Posts: 20
Hello Steam specialists,
when my boiler is running, the flames don't seem to be consistent, as you can see hear in this video. Is this normal ?
https://photos.app.goo.gl/bPbDTT7e2GhwiySx9
No, it isn't normal. Did you clean the burners at the start of heating season? How old is the boiler?
You shouldn't let it run like this. You could be letting carbon monoxide into your house. You need to get it serviced ASAP. You don't necessarily need a steam pro. This is a combustion issue.Just another DIYer | King of Prussia, PA
- 117 Geothermal
