Fluttering flame on burner
kcopp
Member Posts: 4,575
in Gas Heating
I got a call today from a customer that has an 8 yr old atmospheric LP gas water heater. It has run flawless until the last week of so.
It makes hot water but the sound is off. The front part of the burner ring about 6 of the little flames flutter when on.
No sooting.
There are 3 other gas appliances and they all run fine.
Unit is in a dry finished basement up off the floor. Thoughts?
No sooting.
On the Honeywell gas valve where do you check the pressure? I didnt see a port. Draft was good.
The whole place is piped in CSST. Made me wonder about the resonation on that... but its been fine for 8 yrs.0 -
A draft reading only means the flue is functional and there is combustion air in the room. It does not mean the heater is venting or air is getting to the burners properly. Any time there is a question about combustion and there are no combustions numbers to diagnose, we need to seek out a physic and a crystal ball. How many guesses are better than one? None!0
Check for recall with the manufactuers on line. There's a recall for some water heaters port flame assembly replacement free of charge if your water heater matches the brand, model & I believe the serial #. The details will be online. It's good habit to check online before dishing out more cash out of your pocket is what i'm learning. I also had my Hayward pool pump motor go out it was also recalled way pass warranty, but the company still honored the replacement free of charge.0
- 111 Chimneys & Flues
- 106 Geothermal
- 978 Plumbing
- 387 Solar
