boiler cleaning tools
nytech28
Member Posts: 116
hay techs, I came across few boilers with the heat exchangers dirty causing flame to roll back or cause spark ignitor to not work, any cleaning tools out there to clean heat exchanger on a standard boiler ?
Is there a trick to cleaning the combustion chamber without the vac pulling out all the insulation? My 5hp Ridgid vac with a bag inside did great for the CI plates, there was no soot in the air. But I was wondering if it was too powerful for the chamber.EBEBRATT-Ed said:just your standard cleaning brushes and a soot vac for CI boilers
- 117 Geothermal
