boiler cleaning tools
nytech28
nytech28 Member Posts: 116
edited February 2022 in Strictly Steam
 hay techs, I came across few boilers with the heat exchangers dirty causing flame to roll back or cause spark ignitor to not work, any cleaning tools out there to clean heat exchanger on a standard boiler ?
    EBEBRATT-Ed Member Posts: 20,485
    just your standard cleaning brushes and a soot vac for CI boilers
    delcrossv
  • offdutytech
    offdutytech Member Posts: 248
    Maybe a saw saw if it's really bad. N95 is probably a wise idea to wear.
    Owner of Grunaire Climate Solutions. Check us out under the locate a contractor section. Located in Detroit area.
    kcoppcross_skierHap_Hazzard
  • Jells
    Jells Member Posts: 655
    Is there a trick to cleaning the combustion chamber without the vac pulling out all the insulation? My 5hp Ridgid vac with a bag inside did great for the CI plates, there was no soot in the air. But I was wondering if it was too powerful for the chamber.
