Gas Vent Damper - Pilot Vent Plug
Jeff__
Member Posts: 7
The very well established plumbing/heating company in my area recently installed a new Burnham IN4 for me. I was looking over the manuals after the install and noticed the vent plug for the electric damper was taped to the cover of the manual. Since the IN4 has electronic ignition and not a standing pilot, the plug should have been installed, right? A few weeks after the install a more junior plumber from the company (not the lead guy) came back to tighten up 2 unions that where dripping and I questioning him about the plug, he got snippy with me and said "no".
Is there any good reason why this pug would/should not be installed with my setup? Does it make much difference?
Thanks for any feedback!
Jeff
Jeff
Looking at the manual on page 22 it says it's used with both standing pilot and electronic ignition.
I would call the service manager0 -
I’m not sure what you mean by vent plug but... If it uses a Honeywell aqua stat they come with a jumper plug that is removed so you can plug in an electric vent damper. Is that what you’re referring to? If so then no it isn’t used.
Fixer of things
Self employed
HVAC/R0 -
To clarify, I talking about a motorized vent damper. It has a hole in the rotating damper for use with boilers with a standing pilot light and "plug" that you insert in the hole for boilers with electric ignition. (see 2 attached photos). My installer left the plug out and I'm questing why since my boiler has an electric ignitor.ayetchvacker said:I’m not sure what you mean by vent plug but...;
Every little bit helps.
- 87.2K THE MAIN WALL
- 118 Chimneys & Flues
- 113 Geothermal
- 164 Indoor-Air Quality
- 73 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
