Reliability, or the lack of it in the systems we use.
Currently running in my kitchen is one that's 89 years old and another that's 87 years old. Both have the original mineral oil in them. Next to me at work is one that's 87 years old, also original oil.DJD775 said:
Maybe if you could you would have refrigerators that last more than 8-10 yearsChrisJ said:
Under normal conditions with a proper design manual transmission and differential oil essentially is "life time". It doesn't get diluted with fuel or full of carbon and moisture typically isn't an issue. So unless it's leaking, it should be fine.DJD775 said:
I wonder how they got the fluid in there when it was built. Fill it before the axles are installed?EBEBRATT-Ed said:
It has a sealed differential with no way to add or change fluid. How stupid.
I always hate when car manufacturers state that some of the fluids/lubricants are "Lifetime". BS! I want my vehicle to last more than their definition of lifetime.
That being said even the worst cars today a very reliable.
Refrigerator and air conditioners etc all also have "life time lubricants". I don't exactly see anyone running around changing them.
The oil in them is fine.
There's more important things to worry about.
Now, automatic transmissions that you can't service, that could be something to be annoyed about.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
But your 99 I'm sure had some work done to it. Specifically intake manifold gasket etc depending on the engine.ChrisJ said:delcrossv said:All mine are GM (Chevrolet). K2500 Suburban, 2500 Express van, Trailblazer.
Bingo! and machining the heads for flatness. All better now.
I don't really worry about it but fluids are easy enough to change that it's worth my time and I enjoy my time in the garage.ChrisJ said:
My wife's Jeep had a CVT transmission in it that Jeep claimed had lifetime fluid. My friend who is a Jeep service manger said if you want the lifetime to be <150,000 miles don't change it. Otherwise change at 100,000 miles tops. Worst thing about a CVT is that they are pretty much throw away items once they are shot.
Oh boy.................Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
A refrigeration system is sealed,or at least it is supposed to be. A transmission or differential pulls in some amount of dirt and moisture from the environment and works a lot harder than a refrigeration compressor. When the refrigerant leaks out through defective tubing is when modern refrigeration systems fail.0
There's some truth there, but I used to change manual transmission oil and then I stopped.mattmia2 said:A refrigeration system is sealed,or at least it is supposed to be. A transmission or differential pulls in some amount of dirt and moisture from the environment and works a lot harder than a refrigeration compressor. When the refrigerant leaks out through defective tubing is when modern refrigeration systems fail.
I was tired of draining new looking oil out.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
DJD775 said:The appearance of oil gives you little to no information on how the oil is holding up. Without proper chemical and microscopic analysis it's a shot in the dark.
I see no reason to do it on gear oil.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Ah yes the Ford power transfer unit (PTU). The oil in them gets cooked by the catalytic converter which is a whopping inch away from it. It has a fill plug, but they neglected to put a drain plug it it. Only service you can do is finangle a hose in it and such out as much fluid as you can. All with that whipping inch of clearance.....
Funny the manual transmission which I sourced from a 1978 mustang for my 1959 Galaxie also didn't have a drain plug, fill plug only. The boss was there in the iron casting but never drilled and tapped. Well you know what happened when I got my grubby hands on it.Serving Northern Maine HVAC & Controls. I burn wood, it smells good!4 -
- 87K THE MAIN WALL
- 58 Biomass
- 113 Chimneys & Flues
- 109 Geothermal
- 161 Indoor-Air Quality
- 995 Plumbing
- 391 Solar
- 55 Water Quality
- 45 Industry Classes
