Geothermal Power Plants Vox article from 2020
mknmike
mknmike Member Posts: 183
It doesn't look like much is going on in this Geothermal sub-forum, so I don't see the harm in posting this.
I found this interesting and "Eavor loop" sounds good, but I wonder if an earthquake would destroy the whole system.
https://www.vox.com/energy-and-environment/2020/10/21/21515461/renewable-energy-geothermal-egs-ags-supercritical
Check out the Eavor video in there if interested.
hot_rod
    hot_rod Member Posts: 27,405
    I got a tour of the geothermal systems at the Peppermill Resort in Reno a few years back. They have 8 wells on the property, the most recent pumps over 800 gpm of water around 172F, then dumps it into a rejection well. It heats, provides DHW and pool heat for much of the property
    On the recently drilled well they had hoped to get into a hotter source to be able to run absorption chillers for cooling.
    Here’s a shot of the control board the day I visited.
    There are a few hotter  wells providing power around Reno, see the steam  from them when you head south out of town, over that high radiantly heated bridge
