Geothermal Power Plants Vox article from 2020
mknmike
Member Posts: 183
in Geothermal
It doesn't look like much is going on in this Geothermal sub-forum, so I don't see the harm in posting this.
I found this interesting and "Eavor loop" sounds good, but I wonder if an earthquake would destroy the whole system.
https://www.vox.com/energy-and-environment/2020/10/21/21515461/renewable-energy-geothermal-egs-ags-supercritical
Check out the Eavor video in there if interested.
1
I got a tour of the geothermal systems at the Peppermill Resort in Reno a few years back. They have 8 wells on the property, the most recent pumps over 800 gpm of water around 172F, then dumps it into a rejection well. It heats, provides DHW and pool heat for much of the property
On the recently drilled well they had hoped to get into a hotter source to be able to run absorption chillers for cooling.
Here’s a shot of the control board the day I visited.
There are a few hotter wells providing power around Reno, see the steam from them when you head south out of town, over that high radiantly heated bridgeBob "hot rod" Rohr
Living the hydronic dream0
- 125 Chimneys & Flues
