Boiler weight
bclev77
bclev77 Member Posts: 1
I have an old 1960s 6 section oil fired boiler that I have busted apart it stands about 5foot tall cast iron how much can I expect these sections to weight?
  • Big Ed_4
    Big Ed_4 Member Posts: 3,515
    If you broke it in section no big deal . if you need less weight bust up the sections ....
  • ScottSecor
    ScottSecor Member Posts: 1,031
    Assuming it is a typical large house boiler with six sections I would guess about 1100 pounds for wet base and about 800 for dry base.
    EBEBRATT-Ed Member Posts: 20,085
    I would guess 150lb each section average front & back are heavier
