Drain, flush, refill annually?
Bucky
Member Posts: 47
Hey all, me being a glutton for punishment and all, I was reading the comments in a radiator problem question posted on facebook. One of the commentors stated that "you should drain and flush your radiators every year". And it's picked up a bunch of "likes" too.
This is something I'd never heard of- in fact, if pressed, I would say to NOT drain and refill unless there's a specific reason- don't want to introduce more air into the system unnecessarily. I own and have read most of Dan's hydronics books, and I don't recall any recommendations like that in any of those (although it has been a while!)
So with your typical old iron radiator system, is there any interval for drain/flush/fill that I should undertake? Thanks!
Hot water, I should've clarified!0
I can't see any reason for a specific drain and flush -- of the entire system -- unless it is necessary to replace the water treatment or the treatment, if any, was poor and you need to flush that out.
Not the radiators spcifically.
And certainly not for steam.Br. Jamie, osb
