Found something unusual today
Grega
Grega Member Posts: 20
Today i went to look at a replacement of a Weil Mclain EGH 115. No hartford loop to start. Then saw 2 different F&T steam traps piped so the condensate went into radiators below. Did not get pic of that but did get pic of this and almost all of the traps this way. I have seen hot water loops from the boiler but this was interesting to say the least. Also has a condensate reciever. Anyone seen this craziness before? Could there be a reason for this? Thanks in advance
  • neilc
    neilc Member Posts: 3,170
    are you refering to the vents at the traps?
    air gotta go somewhere
    known to beat dead horses
  • JUGHNE
    JUGHNE Member Posts: 11,547
    They may be trying to milk heat out of returning cond water. Not a lot of BTU's in that.
    Some older systems used a ceiling hung rad for a condenser to keep steam out of the return water.
