One radiator started being cold
dsan
dsan Member Posts: 4
​Hi guys, ​I have a 6 years old piping, refurbished cast iron radiators and a new boiler, everything worked well until a couple weeks ago, that one of the radiators in zone II started being cold, on and off, while the other three radiators in this zone were working as before. The valve is open and I have checked for air, also recently had a tech clean the boiler. Any ideas what could be the reason?
    Jamie Hall Member Posts: 27,373
    Hot water or steam? And if steam, one pipe or two? If hot water, how are the radiators piped?
  • dsan
    Hot water, and each radiator is feeding by manifold directly.
  • JUGHNE
    JUGHNE Member Posts: 11,549
    Is this 2nd story? What is the system pressure?
  • dsan
    First floor (top of basement). The system pressure in 19psi
  • Jon_blaney
    Jon_blaney Member Posts: 335
    Are the supply and return runs for these radiators hot at the manifold?
  • dsan
    Yes they are hot at the manifold.
