What I've learned about steam pressure
HeatingHelp
Administrator Posts: 718
Though seemingly counterintuitive, Dan Holohan's solution makes sense once the actual physics of steam transportation are understood.0
After Nests and really strange piping, seems to me that too much pressure may be the most common problem we see!Br. Jamie, osb
To the tech with a screw driver.
Most often less pressure is more steam volume.
JakeSteam: The Perfect Fluid for Heating and Some of the Problems
by Jacob (Jake) Myron0
- 62 Biomass
