I'm not sure what this thing is but I want one
AdamInEvergreen
AdamInEvergreen Member Posts: 42
In summary it appears to be a heat pump that stores heat during the day /warmer temperatures and releases it when needed. This could work well with a number of time of use power schemes (in addition to people with solar); charge up mid day for the late afternoon peak demand, off from 4pm - 8pm, maybe charge up middle of the night when power is cheap for the morning setback recovery or shower?
https://www.pv-magazine.com/2022/01/20/residential-heat-storage-system-uses-pv-electricity-for-space-heating-hot-water/
  • ratio
    ratio Member Posts: 4,219
    Kinda neat, but isn't 2.5 kWh about the same as running a 100 watt light bub for a day? For the quoted 7500 € that seems like a poor investment. Plus, it's metric…
  • JakeCK
    JakeCK Member Posts: 1,502
    edited January 2022
    Yea, at 2.5kwh it's basically useless unless you have a passive house... That's about 5 minutes of run time with my boiler.
