Weil-Mclain; I need to be able to adjust low set point in below zero outdoor temps.
ChillyinMN
Member Posts: 1
I have a Weil-Mclain boiler system. It is not maintaining room heat now that we are below zero F temp.; so, I need to know if I can adjust the low temp. set point up from 160 degrees F to 170 degrees F. The high set point is set to 190 degrees F.
Is the boiler running non stop on those cold days? If so, changing the low/ off setting, if even possible will not change anything.
The heat emitters are in charge of the operating condition of the boiler.Bob "hot rod" Rohr
On mine the low point is a fixed offset (20F) below the set high point, so increasing the high limit increases the low limit as well, which should in theory increase the heat output of your radiators by increasing the average temperature.0
What model boiler and what operating control?
Pics?0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 989 Plumbing
- 389 Solar
