Weil-Mclain; I need to be able to adjust low set point in below zero outdoor temps.
I have a Weil-Mclain boiler system. It is not maintaining room heat now that we are below zero F temp.; so, I need to know if I can adjust the low temp. set point up from 160 degrees F to 170 degrees F. The high set point is set to 190 degrees F.
    hot_rod Member Posts: 26,594
    Is the boiler running non stop on those cold days? If so, changing the low/ off setting, if even possible will not change anything.
    The heat emitters are in charge of the operating condition of the boiler.
  • fentonc
    fentonc Member Posts: 335
    On mine the low point is a fixed offset (20F) below the set high point, so increasing the high limit increases the low limit as well, which should in theory increase the heat output of your radiators by increasing the average temperature.
    HVACNUT Member Posts: 7,233
    What model boiler and what operating control?
    Pics?
