gas valve
billy89
Member Posts: 2
in Gas Heating
i have a honeywell vr8200c3005 cant buy a new one i need one what will replace it dont care what brand need it fast its cold around here
@billy89
If you take it to a heating supply house that sells Honeywell the should be able to cross it to something else.0 -
It looks like that valve is a current part, just out of stock.0
Maybe shouldn't say it so loud but most any VR8200 will work. Some tradesman always prefer the "a" models. Don't fail as often. But you didn't hear that from me.0
The "C" valve is a step opening valve so it must be replaced like for like, Try here https://www.parts4heating.com/Honeywell-VR8200C3005-Heater-Gas-Valve-Nat-p/vr8200c3005.htm
The "a" version is not a good idea.
- 87.1K THE MAIN WALL
- 117 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 55 Water Quality
