I have a VXT programmable water feeder, that usually displays numbers but now it shows nothing?
This meter is supposed to show red numbers and about a week ago, it stopped showing them. I'm wondering what the issue is, and if it is a serious one. Any help will be greatly appreciated. Thanks.
  • Fred
    Fred Member Posts: 8,542
    Does the display show anything, like LOC or ERR? Is there a loose terminal/wire either on the VXT or the wire at the Low Water Cut-off? You might try to push the reset button (Red button) just be aware that that will reset the display to zero water used.
  • If it displays nothing it has lost power or is kaput.
    New England SteamWorks
    newenglandsteamworks.com
  • yeezyslot
    yeezyslot Member Posts: 2
    There is no sign of any red letters/numbers at all Fred. and NE steamworks. There was no red button for resetting, only the feed switch. NE steamworks- I'm afraid that might be the case, if so, what is the next step.
  • Can you check with a meter for power coming into the unit?—NBC
  • Fconway
    Fconway Member Posts: 1
    It shows Loc.
