Can anyone ID this radiator
cross_skier
Member Posts: 201
Measuring almost 4 feet wide, less than 4" thick. I wonder how it would do on a single pipe system.
https://www.ebay.com/itm/115096573913
It is a little more ornate than most but it is a pretty standard wall hung utility radiator.0
Thanks. Do you know if they are as quiet as a normal steam radiator0
Yes, they are.All Steamed Up, Inc.
Consulting0 -
Thanks @Steamhead, I brought it. I mounting it on a very solid interior brick wall in the front hall. Any idea what the brackets looked like?
We are going to do it in gold. Probably reduces the EDR a bit but it looks like it has enough EDR
Trying to squeeze the best out of a Weil-McLain JB-5 running a 1912 1 pipe system.0
thanks delcrossv for the link, would like to overhaul this setup post heating season, and looking for additional support hardware as the current setup has the weight of the radiator point loaded on a single support and without enough pitch. Check out the custom piping, don't usually see the spud nut attached outside the radiator. Currently functional and I dont dare mess with it as it is closest to the thermostat and its supposed to get cold this weekend, the BWH1 may be just the thing I need
That's uh...creative...0
My wall mounted raditor uses these stays: https://www.castrads.com/us/product-category/stays-fixings/wall-stays/whitworth/
I don't know why they call them Whitworth. The threads are metric.Just another DIYer | King of Prussia, PA
Thanks @Hap_Hazzard0
Glad it's working for you, but I'm a little creeped by a single sling. I'd add another. If it's not deflecting anything, it'll keep until spring.
Well done. 👍Trying to squeeze the best out of a Weil-McLain JB-5 running a 1912 1 pipe system.0 -
@cross_skier, that's the American Radiator Company's Colonial Wall Radiator. Here's the source from The Ideal Fitter, 1904.
President
HeatingHelp.com5 -
@Erin Holohan Haskell.
Thank you!0 -
You're welcome, @cross_skier. It's always fun browsing through our heating library.
President
HeatingHelp.com0
