Balancing valves
Steve_210
Member Posts: 647
Balancing valves
Who makes these just looking for the test kit
What do you mean who makes them? Tour & Andersson is right on the tag in your hand0
Any brand of pressure differential meter will connect to those PT ports you see
Look up the manual for the valve for setting info
I think T/A is part of Victraulic now?
Dwyer, B&G, have meters available they are $$&Bob "hot rod" Rohr
Thanks I have the backflow prevention test kit but I’m not sure if this can be used
Is there a number for anybody I could discuss this with0 -
Maybe a rep for The Victaulic when I Google it it brings me to Victaulic0
Any pressure differential meter will work, but you need the T/A chart to convert the reading to GPM. Most meters are digital now.
Plenty of T/A You Tube vids showing how to balance their valves.
The Victraulic site should have a T/A section, like this
http://www.researchairflo.com/wp-content/uploads/2014/09/TA-Tour-Andersson-Balancing-Valves.pdfBob "hot rod" Rohr
- 87K THE MAIN WALL
- 58 Biomass
- 113 Chimneys & Flues
- 109 Geothermal
- 161 Indoor-Air Quality
- 996 Plumbing
- 391 Solar
- 55 Water Quality
