Anyone use a sight glass float ball for quick reference?
Bodycount
Bodycount Member Posts: 43
edited January 2022 in Strictly Steam
Something like this.
  • Derheatmeister
    Derheatmeister Member Posts: 1,659
    yes..On solar system tanks.
  • Bodycount
    Can it be used in a residential steam boiler sight glass?
  • JUGHNE
    JUGHNE Member Posts: 11,532
    The sight glass with the heavy red line are easier to read.
    I think the ball might get hung up and be misleading.
  • Derheatmeister
    i have never seen on hung up
  • Dan_NJ
    Dan_NJ Member Posts: 268
    The first time I opened my sight glass valve to flush it that ball would be in the bucket.
    SuperTech
    ethicalpaul Member Posts: 8,513
    It wouldn't fit out the valve, you'd have to remove the glass. It doesn't bother me, but I don't really see the need for it...but then I have a small basement :joy:
  • AdmiralYoda
    AdmiralYoda Member Posts: 770
    I just have a line that I drew with a permanent marker. I have two lines....the "Fill To" line about 2/3rds up the sight glass and a line about a third way up the sight glass.
    If I'm not there I can ask my wife to check the sight glass and if it reaches the bottom line....fill it until it hits the top line.
  • ChrisJ
    ChrisJ Member Posts: 17,197
    I don't see why you can't use them.
    I always thought they were meant for steam boilers.
    I went with this style glass.
    SuperTech
  • JUGHNE
    Yes, the red line. Or hold your hand behind the glass.
    On a water clean up project from leaking UST at gas station, we were pumping water that was slightly tainted with oils etc.
    I put a clear tube sight "glass" on the 1000 gal holding tank and put a fishing bobber in the tube. The trace of oil would make the float cling to the tube.
    I am thinking a little oil in the steam water might do the same.
    Of course in theory there should be no oils left in a clean boiler. ;)
  • Bodycount
    The boiler that’s been giving me stress is at a two family I own & maintain.
    The image above is a Ring Wi-Fi camera, so can monitor it on my phone.
    I like the redline glass but my local Wallington Plumbing only has clear and I bought 3.
    I’m gonna order the ball & report back.
  • ChrisJ
    edited January 2022
    I think the ball will work perfectly.
    But your boiler also looks like it's in desperate need of skimming
    Or not.  I see what you mean the water is higher than the dark area
    Bodycount
  • Bodycount
    Skimming. YES! Thanks.
    I’m otw to pickup the hardware. I’m pretty sure it’s 3/4”.
  • ChrisJ
    For skimming?   1 1/5" I think but it's been a while.
    The gauge glass I think is 5/8"
  • JUGHNE
    Chris, 1 1/5"???....it has been awhile. ;)
  • ChrisJ
    Oh boy.
    1 1/2".
     :o
    I've got a lot of numbers going thru my head
  • Bodycount
    Definitely 1 1/2” as I brought everything else.
  • CLamb
    CLamb Member Posts: 348
    If it's rusty water than is making the level hard to read you can stick a magnet to the side of metal rod on the side. That will draw all the rust particles to a spot near the magnet leaving the rest of the water mostly clear.
    Bodycount
  • Hap_Hazzard
    Hap_Hazzard Member Posts: 2,919
    But rust is virtually nonmagnetic. Also, a little rust in the water makes it easier to read, as long as it doesn't build up on the glass. I use a small black cable tie to mark the water level on my gauge glass. I tried painting it, but that wore off, then I etched it, but that was too faint. The cable tie works great.
  • mygardenshed
    mygardenshed Member Posts: 51
    edited January 2022
    I put two o-rings around the outside of the glass. One at max and one midway to min.
    Sometimes use the lower one as a reference to see if things are consistent as far as water use goes.
  • ChrisJ
    I just keep my water half way to 3/4 up the tube.
    Never thought it was precise enough to require markers.
  • BobC
    BobC Member Posts: 5,554
    edited January 2022
    I just put an index card behind the sight glass to make it easier to read.
    Bob
    3PSI gauge
