Which Testo Combustion Analyzer?
Member Posts: 4,665
My Bacharach has to be sent in for repairs and I need a backup. Testo seems to rise to the top here on HeatingHelp for recommendations and I want to zero in on the model I need. Most of my work is on natural gas boilers and typically need O2, CO2 and CO readings. A printer would be great. I see that they have models with extended sensor warranties. Are they worth it?
The models that I've seen so far are the 300, 320, and 330. Any further recommendations or input?
Thanks!
Thanks!
I'm sticking with the Insight...
I have used the 300, 310, 320, and 330 models all through my previous employer. The 310 seems to be the most reliable, but still less than I feel is acceptable. I maybe use a CA 10-20 times per year and it seems none of them are able to go more than 6 months without being sent in for repairs, whether they've been used once or 100 times. 320 was by far the worst IMO, I had several of them and they were constantly in being repaired. I'm done with gas boilers for the season so I won't be buying one just yet, but when I do, I think it's going to be an Insight.0
Not a Testo but I found the TPI 710 to be very user friendly and a good value
https://forum.heatinghelp.com/home/leaving?allowTrusted=1&target=https%3A%2F%2Fwww.trutechtools.com%2Ftpi-dc710c1-flue-gas-analyzer-kit.html%3Fgclid%3DCjwKCAiAsOmABhAwEiwAEBR0ZkP-JJPxlej6Biq1eF9V3_yxgMP_n7McSablouKDnqBFSyjm91fEXxoCuywQAvD_BwE
I just got the UEI Bluetooth version, only used it twice but I like using the app to see the readings. The analyzer itself does not have a screen, very rugged and you don’t need to hold or hang it in sight it to operate. Also came with a printer and a nice soft bagBob "hot rod" Rohr
Living the hydronic dream0
- 15.8K Strictly Steam
