System 2000 ek1
Akwood94
Member Posts: 2
in Oil Heating
Have been having “no ignition” issues. Have replaced everything you can think of (cad cell, igniter module, control panel.) have had it serviced cleaned out and all. Still shows “no ignition” when it hardlocks after bout 10 cycles. It’s a repeated thing. Run for bout 10 cycles till it hardlocks and has to be reset again. Any ideas?
Call the service provider back and tell them the problem wasn't resolved on the first visit.
It seems oil related, like a suction leak or clogged line.
Where and what type of oil tank?
One pipe or two?0 -
Pressure switch0
Thank you for your post @Akwood94 , and for the good comments posted here as well.The below link can help your heating professional diagnose the issue, or please have them call our tech support line while they are working on your system.RogerPresident
Energy Kinetics, Inc.0 -
Faster than the bat signal...DanHolohan said:How's that for service?
Yeah.Retired and loving it.0
