Crazy Ideas...
JakeCK
Member Posts: 1,496
I have a decently large aquarium in my living room that I keep heated to slightly over 80f using a multiple submersible resistance heaters in a sump.
Have any of you heard of an aquarium heated by either a boiler and heat exchanger or even a hpwh in a home setting?
Like I said crazy ideas but resistance heating is expensive and it runs year-round.
You could be the first on your block.
It certainly sounds do·able; just a miniature one that they use in the commercial aquariums.
Probably a PITA when all is said and done.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
You could be the first on your block. It certainly sounds do·able; just a miniature one that they use in the commercial aquariums. Probably a PITA when all is said and done.
At the end of the day I probably would never do it unless and until I have my man cave in the basement. This is more academic than anything else atm.0 -
There is a recent post here with some guy using his wood boiler with temp valve to heat his 120 gallon aquarium.0
Larry Weingarten said:Hi and happy day! Getting maybe a bit too creative here, how about such a big aquarium in the room that it becomes the heater for that room? Anyone know what the heat output per foot of aquarium is?
Yours, Larry
That reminds me of my poor late father. He loved his aquarium. His 3-4 goldfish were 10+ years old. They were large with the crowns on their heads. One time in the summer he forgot to turn off his aquarium light, and it was over... they were cooked.Tom
Montpelier Vt0 -
in a home setting? No. But at work we had a 10,000 gallon fish tank that we heated with heating hot water through a heat exchanger. You might be able to do it with a domestic hot water heater thru a HEX.
Edit- I might be wrong about the HEX. There were also two holding tanks; one about 1000 gallons, the other about 5000 gallons that were in mechanical rooms where RO water was warmed with ambient air and salted. It was a complicated system. Temp was kept around 70.0 -
MikeAmann said:If it goes wrong, then you get to have a fish dinner.
Tom_133 said:That reminds me of my poor late father. He loved his aquarium. His 3-4 goldfish were 10+ years old. They were large with the crowns on their heads. One time in the summer he forgot to turn off his aquarium light, and it was over... they were cooked.SlamDunk said:in a home setting? No. But at work we had a 10,000 gallon fish tank that we heated with heating hot water through a heat exchanger. You might be able to do it with a domestic hot water heater thru a HEX. Edit- I might be wrong about the HEX. There were also two holding tanks; one about 1000 gallons, the other about 5000 gallons that were in mechanical rooms where RO water was warmed with ambient air and salted. It was a complicated system. Temp was kept around 70.
I just have a tropical tank so not nearly as complex, or sensitive. One of the reasons I went large was for stability. The larger the water volume the easier it is to maintain water parameters. Why I added a large oversized sump too.
At 70f little to no heating would be necessary as long as the building was heated to a sensible temperature. If I let my house go to 77 - 78 in the summer the heaters don't run at all. If I let it go over that the tank starts to slowly overheat.. Waste heat from the lights, pumps, and solar gain and just gain through the wall does it. Winter I suspect that it would track closer to the ambient and would not over heat. I have insulated the sump and bottom of the display tank to help a little bit.0
- 110 Chimneys & Flues
- 981 Plumbing
- 387 Solar
- 17 Recall Announcements
