Gould gland plug
I am not much of a plumber. I do heating. But... every so often I got an older buddy who needs help.
This guy has a Gould Shallow well pump. He needed a new tank and didnt want to cough up the cash for a Gould replacement tank. So he needs to plug the Gland inlet brass fitting that the copper line from the tank to the inlet on the pump. Its an odd size. Anyone know what kind of fitting that is? It looks like a brass fitting with G threads and a gasket.
Tom
Montpelier Vt
Montpelier Vt
Was this the air inducer line that is to keep air in the top of the tank?
Can you just cut the copper line and cap it?0 -
I found it online as the discharge gland. https://www.pumpproducts.com/goulds-4k12-dis-gland-nut-assembly-includes-26-27-brass-fit-models-jrd5lt.html
he probably could have taken it off and capped it, but he tore it apart, and now I dont know
Tom
Montpelier Vt0 -
G threads are parallel, not tapered, so it makes sense there is a gasket.
British Standard Pipe Parallel thread (BSPP) - G
British Standard Pipe Taper thread (BSPT) - R
The terminology for the use of G and R originated from Germany (G for gas, as it was originally designed for use on gas pipes; R for rohr, meaning pipe.)
https://en.wikipedia.org/wiki/British_Standard_Pipe
McMaster-Carr has them
https://www.mcmaster.com/plugs/thread-type~bspp/0 -
Hi, Can't help it, but things make sense now. "R for rohr, meaning pipe". Now I understand why @hot_rod says "Living the hydronic dream". He's made for it!
Happy Holidays
Yours, Larry0
- 50 Industry Classes
