Replacement Steamer
Dan Foley
Member Posts: 1,258
Brian, Dragon and JJ popped this one in last week. Peerless 64-10 in a 100 year old stone house in Warrenton, VA. Cast iron was scarce locally. I had to send my driver to NJ to find this one. Thank you Henry. Henry’s Plumbing Supply, Hawthorne NJ.
5
Impressive0
Wow, that's a lot of boiler. Very nice!
Why did you decide to take the mains off at 45 degrees rather than straight up? Header pitch?Trying to squeeze the best out of a Weil-McLain JB-5 running a 1912 1 pipe system.0 -
How does your crew like the newly designed/adjustable valve VXTs?All Steamed Up, Inc.
https://heatinghelp.com/find-a-contractor/detail/all-steamed-up-inc0 -
It's a good thing the header is hung the boiler could tip over!! LOL
Nice job0 -
Wow from VA to NJ! Henry's is where @clammy sent me to get my Peerless! But it was only a 30 minute driveNJ Steam Homeowner. See my sight glass boiler videos: https://bit.ly/3sZW1el0
Nice work0
This!EzzyT said:@Dan Foley beautiful job as always.
Consulting0 -
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 130 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 885 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
