Boiler gauge
beam
beam Member Posts: 1
edited December 2021 in Gas Heating
As i am new to this heating system, heating is not good enough. Checked the gage, can anybody tell me if i am in the right track ?
  • Larry Weingarten
    Larry Weingarten Member Posts: 4,005
    Hi @beam , I can promise you that people here are going to want much more information about your system, and photos of it as well. Only then, can they give you good advice.
    Yours, Larry
    beam
    EBEBRATT-Ed Member Posts: 19,543
    @beam
    your temperature is a bit high. it should be adjusted to be around 190 maximum
  • neilc
    neilc Member Posts: 3,116
    a bit high?
    where are you?
    pictures of boiler, floor to ceiling, showing pipes, pumps, zone valves,
    and a picture of a rad where this 220 is going,
    is there water dripping from the safety valve ?
    known to beat dead horses
