BTH-400A
heidleml
Member Posts: 36
I was called out to provide a solution to the noise of a 2019 water heater. It is an AO Smith BTH-400A installed in the basement of a 23 unit multifamily complex. We did not spec or install the heater so we are in a good position to provide the solution. The building super has exhausted options with sound proofing companies and apparently no one east of the Mississippi will touch the job. It looks like a fine install, it is just directly under one of the units with little barrier to sound. These buildings used to have atmospheric heaters which produced virtually no sound at all. I went down there and measured decibels at 80 when the fan had ramped up. Any ideas on good replacement heaters that would be much less noisy? My first thought was a Rinnai Demand Duo but couldn't find decibel specs.
Hi, In worst case, is there any reason you can't go back to atmospheric draft? Also, getting in touch with the manufacturer to see if they have any suggestions MIGHT lead to a less expensive outcome for the client. The current heater is a 95% efficient unit, and not very old, so it would be nice to find a way to quiet it down. As @Zman asked, can you identify the source of the noise... all fan noise? And lastly, is the venting done to spec?
Yours, Larry1 -
@Zman Normal fan noise not flutter.
@Larry Weingarten Going back to atmospheric would mean installing new chimney. Venting is done to spec- goes into a concentric kit.
@tim smith 23 units, 12 are kitchen, single bath w/ tub, 11 are kitchen 1.5 bath w/ tub. 2 commercial washing machines in common area.0 -
These units are by far , the quietest and most efficient I have encountered . 2 combustion assemblies allow for greater efficiency also .
https://htproducts.com/literature/MKTLIT-52.pdf
https://htproducts.com/literature/lp-454_0921.pdfYou didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
Rich McGrath 732-581-38330
