Trane
keith123
Member Posts: 105
Anyone have any sizing charts for these. I contacted Trane. They don’t keep an archive. The convectors in Dans book are from the 50’s. The convectors are behind the plaster walls with an opening in the wall below the convector. Above it there’s a wall grill about 6” tall or so by the width of the convector. There’s wooden handles on the grill that say Trane carved in the wood.
Thank you
Not specifically. But if you measure the size of the finned element and count the # of fins/inch and the fin size like 4" x 6" etc and compare that to a new convector you will be close enough.
You can also search this site in the library and perhaps find some information0 -
Wow you still have the air damper ....
I think there used to be some brochures in the library here too, although your's looks a bit newer than the brochures I have.0
- 167 Indoor-Air Quality
