Lochinvar Noble Combi 199--- very little hot water
TBL
Member Posts: 1
Brand new installation of Lochinvar Noble Combi, propane, even though the temp DHW is set above average temp, we are getting very little hot water before it runs cold, 10-12 seconds worth. Before installing the recirc loop with aquastat the volume of hot was plentiful. Of course that was before the space heat season triggered that demand on the unit too. Advice? Yes, if we turn off the tap for a minute or two it will warm up then be hot for another 10 seconds.
could be a cross connection in the piping? Is there a thermostatic mixing valve in the piping
Does the boiler continue to run when hot water is flowing? Could bet the recirc pump is closing the flow switch that triggers the boiler and diverter valve insideBob "hot rod" Rohr
You may need to post some pics of the recirc loop install. More than likely thats the culpritTom
Montpelier Vt0
