Connecting Taco Controls and Nest Thermostats
HeatingHelp.com
Member, Moderator, Administrator Posts: 219
Here are instruction sheets for Nest to Taco ZVC with 3-wire application, Nest to Taco ZVC with 2-wire application, Nest to Taco SR with 3-wire application, and Nest to Taco SR with 2-wire application.
Forum Moderator
Erin and all,
We have also spoken with Nest recently in regards to wiring and they suggest using the resistor wiring as shown but they do suggest using a 220 ohm, 5 watt resistor instead of the 1,000 ohm, 0.5 watt resistor we supply with the controllers.
Dave H.Dave Holdorf
Taco, Inc
Also make sure to pre-charge the Nest so that the battery is at 100% before wiring to the ZVC or SR controls.0
Do the Taco ZVCs apply power to close the valves, or are they assumed to be self-closing? Said differently, does the Nest connect power from Rh to W1and C respectively when calling and not calling for heat?0
Is there a similar instruction sheet for Nest to Taco XPB-1 with 2-wire application?
Many thanks!
- 116 Geothermal
- 169 Indoor-Air Quality
