Triangle Tube Instinct Combi 155
I'd considered the Navien, ICB, Triangle Tube, and Lochnivar( prob my 1st choice, but not really available in my area. (At least not with a definite, reliable, experienced installer , which, as I learned here, is hugely important!)
So I went with a local company with 23 years experience that deals primarily with TT.
Ok, so, here it is, and I'd love to hear your feedback...how's it look? Job well done?? Thanks!
Looks good. Curious on condensate removal. I could do that in mass for condensate removal. It would have to be a true vented trap0
Looks good to me.0
Umm....Huh?Fpipes said:Looks good. Curious on condensate removal. I could do that in mass for condensate removal. It would have to be a true vented trap1 -
Any feedback after a winter ? Plenty of domestic HW when it was cold ?0
I’m considering buying one too and wondering if a storage tank after the boiler would make sense. I assume it would be easy to use my existing two gas water heaters to help even out the temps, maybe wrap those babies in a ton of insulation too.
Been a long time since I installed a TT, but Is schedule 80 PVC no longer required for exhaust air?
It depends on your location. Triangle tube has allowed (where legal) to install sch 40 PVC vent since the PS series prestige at least. If your location requires a UL listed venting material then you must use a category iv UL listed vent. Regular sch80 PVC doesn't check that box, IPEX makes a UL listed PVC and CPVC, stainless steel from several manufacturers, and polypropylene from a few manufacturers. If your local code doesn't require UL listed vent then you can use sch40 PVC in the US
- 119 Chimneys & Flues
- 116 Geothermal
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
