Using a boiler DHW coil as a HX for a hydronic loop?
delcrossv
Member Posts: 2,203
Settling in on a 19HE as a replacement boiler and in my size range I can order with up to two DHW coils. Can those be used as a HX for a hydronic loop ? That would solve dissolved air entry into the loop and associated corrosion issues.
In this case I'd just pipe it like a conventional HW loop? (compression tank etc?) but with a bypass to adjust temperature?
This article discusses various options for running a hot water loop off a steam boiler. The Systems Help Center has some other articles you might find helpful.Just another DIYer | King of Prussia, PA
1983(?) Peerless G-561-W-S | 3" drop header, CG400-1090, VXT-242 -
We installed a reverse indirect on a system without o2 barrier to mediate between a Viessmann and PB tubing..Works great.0
- 50 Industry Classes
