Using a boiler DHW coil as a HX for a hydronic loop?
delcrossv
delcrossv Member Posts: 2,204
Settling in on a 19HE as a replacement boiler and in my size range I can order with up to two DHW coils. Can those be used as a HX for a hydronic loop ? That would solve dissolved air entry into the loop and associated corrosion issues.
In this case I'd just pipe it like a conventional HW loop? (compression tank etc?) but with a bypass to adjust temperature?
    mattmia2 Member Posts: 17,222
    Yes. Aquastat on the boiler to heat it for the hot water loop but not cause it to steam on a heat call. Needs a relief valve.
    Don't need a bypass in most cases, what do you think you need it for?
    delcrossv
  • Hap_Hazzard
    Hap_Hazzard Member Posts: 2,919
    This article discusses various options for running a hot water loop off a steam boiler. The Systems Help Center has some other articles you might find helpful.
    Erin Holohan Haskelldelcrossv
  • Derheatmeister
    Derheatmeister Member Posts: 1,659
    We installed a reverse indirect on a system without o2 barrier to mediate between a Viessmann and PB tubing..Works great.
