Ghost flow mystery
rattmoy
Member Posts: 5
I have a zone that is drawing hot water even when the circulator pump is not running. The plumbers installed a new circulator which didn’t fix the issue. Next they added new piping to loop back to the radiant mixing block which also didn’t help. I can’t help but think that there is a problem with the ifc in the new circulator. Any other ideas on why this is happening? I’ve attached a photo which shows the new pump and new piping. Thank you!
Slab leak?0
It looks like you have several circulators working against each other with no hydraulic separation.
Did this work at one time? If so, What changed?"If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
In that second picture, what is with that bypass? It looks new.
So re reading, the problem existed before that? You need to find someone that knows what they are doing. This sounds like they are just trying stuff at random instead of thinking through what is happening and possible.0 -
TACO says the IFC is included with the circulator. Perhaps the IFC needs to be install when the pump is put in service. Yours may still be in the box.0
Doesn't seem to be piped right? One sensor removed and display reads oPn?Bob "hot rod" Rohr
Living the hydronic dream0
- 121 Chimneys & Flues
- 15.8K Strictly Steam
