Tekmar 518 thermostat to the 3200 Hydrostat wiring
NoelAnderson
Member Posts: 50
I am wanting to connect a Tekmar 518 thermostat to the 3200 Hydrostat in a FORCE04ENRHG1 boiler (rebadged Burnham). Can I connect the C terminal of the Tekmar 518 to the Z terminal of the 3200 Hydrostat or must I use a separate transformer instead of the one in the Hydrostat? There are no zone valves or any other controls except what is on the boiler for the Feild's damper and the Honeywell ignition and gas valve. I will be connecting the Tekmar's R terminal to the Hydrostat's TV terminal and the Tekmar's W1 terminal to the Hydrostat's T terminal. The Hydrostat's instructions does not say anything when a T-Stat needs a common - wire.
Thanks
Noel
Thanks
Noel
I just talked to support at Hydrostat and they said that their 3200 Hydrostat cannot even supply enough power to handle an electronic thermostat.0
- 167 Indoor-Air Quality
