Riteway wood/coal burning stove
MikeAmann
Member Posts: 998
We haven't burned in years - and have no intention of burning again.
It's very similar to this except it has the water jacket on top (no leaks): https://www.hearth.com/talk/wiki/riteway/
Tap it into your hydronic heating loop, light a wood fire before you go to bed and it will last all night and your boiler or furnace will not run at all. And your basement will be warm enough for you to be in your underwear.
It's time to pass this on to someone else. Not junk, not even close - I could light a fire in it right now (if the pipe wasn't clogged).
FREE if you are actually going to use it and not turn it in for scrap metal. I can do that myself. Mike, Meriden, CT.
That looks like a really interesting appliance. It was a bold and innovative attempt at what is now a standard for indoor, wood-burning boilers-- which are all mechanically down drafted. The Riteway was non-electric! The first UL listed downdrafter.
Upon reading, the fuel and burning management of the Riteway seems very cumbersome and time consuming. That, and the economic climate is probably the cause of its demise.
Of course what is not mentioned (and could possibly be a game-changer) is operating the unit with an HEAT STORAGE tank--which ALL solid fuel heaters should be operated with for the sake of convenience and efficiency.
Thanks for posting that historic info. Good luck with the Riteway. Don't scrap it!0 -
GONE. I hope the new owner can make good use of it.0
Generous offerBob "hot rod" Rohr
Living the hydronic dream0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
