Gorton main vent venting steam
Don_175
Member Posts: 176
We have a relatively new Gorton vent on a branch in our basement. It is about 6-8” above the pipe on a pipe nipple and is releasing steam when the heat is on. Is there any way to clean it etc? They seem to be pretty expensive. Thanks
I would contact Gorton, they have excellent customer service and would most likely replace it. If it’s new it shouldn’t be dirty already and it shouldn’t vent steam.0
@Don_175
Do you know if you are running high steam pressure? High pressure kills vents. Should keep it below 2 psi lower is better0 -
No. Pressure is definitely low. .5 psi0
- 50 Industry Classes
