Utica Hydronic Boiler Installed too low to Change the Gas Valve
allthumbs
Member Posts: 10
I've invested time and money refreshing all the accessories on my 37 year old boiler: Pressure feed valve, zone valves, drain valves, air separator, and circulator. The one item I can't replace is the gas valve. The HVAC contractor placed the boiler directly on the basement floor, instead of raising it up on bricks or other masonry supports. The gas valve body is too high to unscrew it 360 degrees without the solenoids hitting the floor. If I hire the right plumber/HVAC guy, can he figure out a way to change the valve without having to disconnect the boiler from all the piping and jacking it up? I was thinking the solenoids on the old valve could be cut off with a sawsall, that would permit the old valve to be removed. The new valve would need to have "low profile" solenoids. Are there "low profile" valves, or am I looking at a major boiler disconnection?
^ WHAT HE SAID ^
@allthumbs
Instead of cutting I am sure your technician can remove the burner manifold and burners if necessary to replace the valve. There is always a way.
But why do you want to replace it if it's working?1 -
If the part is in need of replacing, is it possible to remove some of the floor? A hand sledge and long cold chisel will remove basement floor material immediately below the gas valve. If the boiler can't go up... make the floor go down.
Thank you mattmia2 and EBEBRATT-Ed, I took a look and now I see that the entire manifold can be removed. Thankfully, the manifold is a straight run with no bends. I might have tried to change out the valve if it could have been unscrewed from the manifold ( that's the way the youtube guys do it). I'll get a trained tech to do the job when the valve's time is up. BTW, how much longer can I expect a 37 year old White Rodgers gas valve to last?0
@allthumbs
Until the boiler needs replacement. Who knows? I replaced my boiler it was at least 45 years old and the same valve still worked1
