Snow melt/ boiler type
nikos
Member Posts: 16
Hey guys
i have install snowmelt tube 3/4 under my driveway, with insul tarp and covered with tar.
The area is 2000 square feet.
Any suggestIons on what type of boiler and btus.
It’s like 10 loops. I will
split in 2 manifolds.
Can anyone size it up ?
thanks in advance
thanks in advance
How we we quickly do you want to melt? 100 btu/sq ft would be the low end. Mod con, heat pump, or copper tube boilerBob "hot rod" Rohr
Tubing is laid on top of concrete slab
then 2” mud job and 2” of asphalt
yes looking to install mod condensing boiler
fill it with glycol
any suggestions?0 -
This is what I would recommend.. https://www.ibcboiler.com/consumer/products/sl-series/0
