Vitodens 200 Question
netkick
Member Posts: 9
in Gas Heating
I just got a Viessmann Vitodens 200 installed. Can anyone tell me what the "Operating hrs" means under the Information > General menu. The number reported there doesn't seem to be how long it's been powered on for and I don't think makes sense for how long the burner has been active....so wondering what it's reporting.
I think you must be in the program of Operational Hours/Allowed time span of heat production without setback..It is probably in Military time..
What kind of heat distribution do you have Radiant or Baseboard ?0 -
Derheatmeister said:I think you must be in the program of Operational Hours/Allowed time span of heat production without setback..It is probably in Military time.. What kind of heat distribution do you have Radiant or Baseboard ?
I have two zone circuits setup in the boiler, one with radiant and baseboards using outdoor reset, and another with a Hydro air system using a fixed 166 degree setup. There is also an indirect DHW tank with priority.
None of the zones appear to have been running all that much when I'm home and observing, it's been unseasonably warm recently. So, 68 hours since the boiler was installed a little over a week ago seems inconsistent to me and therefore I'm wondering more about what it means.0 -
It could be that Viessmann tested it for 40 hours before sending it out.
Is it the new B2HE model?8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
It could be that Viessmann tested it for 40 hours before sending it out. Is it the new B2HE model?
It's the B2HB model.0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 163 Indoor-Air Quality
- 71 Pipe Deterioration
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
