Best Manifold for radiant
mhausmann
Member Posts: 3
Need advise on the best brand of manifolds. I need to order the manifold for my radiant system, it will be a 10 port manifold with flow meters.I see Wells, Shark, etc.
Is one brand better than the other?
I've been very happy with the Watts stainless steel manifolds but all the major players make reliable stuff.Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes0 -
No one wants the basement flooded in winter so go with the best one..... Every penny is worth it!
CALEFFI
https://www.caleffi.com/international/en-int/catalogue/pre-assembled-distribution-manifold-6686c5s1Thank you,
Hiren Patel0 -
My favorite local supplier stocks Rehau Pro-Balance manifolds and I've used them for years.
https://www.rehau.com/us-en/pro-balance-manifolds8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Two btu per sq ft for degree difference for a slab1
- 87.2K THE MAIN WALL
- 118 Chimneys & Flues
- 113 Geothermal
- 164 Indoor-Air Quality
- 73 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
