Different size mains off common header?
delcrossv
Member Posts: 2,203
Is there any reason not to take different size mains off a common (larger)header?
E,g,:
Main 1- 2 1/2"
Main 2- 2 1/2"
Main 3- 2" The 2" is shorter then the larger ones.
Header is 4"
Thanks!
E,g,:
Main 1- 2 1/2"
Main 2- 2 1/2"
Header is 4"
Thanks!
No, how else would you do it?0
(??)Take them all up the same size and reduce the small one further down the line? (??)EBEBRATT-Ed said:No, how else would you do it?
Makes life simpler to take the different sizes all the way to the boiler. Glad to know there's no secret sauce with this.
- 50 Industry Classes
