Different size mains off common header?
delcrossv
Member Posts: 2,204
Is there any reason not to take different size mains off a common (larger)header?
E,g,:
Main 1- 2 1/2"
Main 2- 2 1/2"
Main 3- 2" The 2" is shorter then the larger ones.
Header is 4"
Thanks!
E,g,:
Main 1- 2 1/2"
Main 2- 2 1/2"
Header is 4"
Thanks!
No, how else would you do it?0
(??)Take them all up the same size and reduce the small one further down the line? (??)EBEBRATT-Ed said:No, how else would you do it?
Makes life simpler to take the different sizes all the way to the boiler. Glad to know there's no secret sauce with this.
Trying to squeeze the best out of a Weil-McLain JB-5 running a 1912 1 pipe system.0 -
- 120 Geothermal
- 394 Solar
