STONE SILENT GLOW DIESEL HEATER, NOZZLE SEVERELY SOOTED, WONT LIGHT
BHOLBROOK
Member Posts: 1
in Oil Heating
STONE SILENT GLOW DIESEL HEATER, NOZZLE SEVERELY SOOTED, SEEMS TO SPARK, BUT WILL NOT LIGHT. NOW WILL NOT DO ANYTHING. HAS A SUNDSTAND PUMP, A1VB-7013, 3 GPH, 1725 RPM, 100 PSI PUMP THAT SEEMED TO WORK BEFORE THIS PROBLEM. HEATER ACTUALLY SEEMED TO SPIT FUEL WHEN IT WOULD STRUGGLE TO START BEFORE. WONDERING IF IT HAS PROPER NOZZLE IN IT? WHEN IT LIGHTS IT DOES SEEM TO WORK WELL. STRUGGLES TO START AT TIMES.. I REPLACED THE ORIG TRANSFORMER (JEFFERSON ??) WITH A CROSS REFERENCED DONGAN A05-SA6 LAST SEASON, SEEMED TO WORK OK, BUT STILL HAD STARTING ISSUES AT TIMES. ANY THOUGHTS FROM THE EXPERTS? THANKS IN ADVANCE!!!!
I have worked on many space heaters. I know diesel is cheaper to run, but you are always better off running kero. Post some pics, also does it have what looks like a long spark plug for ignition? Correct nozzle size for it? Filter and strainer replaced? Two pipe fuel system?0
Those aren't made anymore.
When they don't work, it us usually a vacuum leak on a loose oil fitting. Its just a standard oil burner.
If you are the same person out on the Internets, looking for a part you broke, it may not work until you get the correct parts.
Anyone slick with oil burners should be able to troubleshoot that thing easily and get it running. Its not a job for trial and error mechanics. You only need fuel and ignition for them to run. Without one or the other, they won't run.0 -
can anyone point me in the directions of spare parts and/or a manual. does anyone have any idea what kind of gap is required between the two electrodes or how much voltage is required at the electrodes, guess a manual would have this information. my heater is a stone silent glow sg300. the electrode for this machine does not look like a spark plug.0
I'M BEING TOLD THAT YOU CANNOT FIND PARTS FOR THE STONE SILENT REFERENCED ABOVE. IS THIS TRUE?0
ALSO KEVINJ, YOUR CORRECT, THE PUMP IS BELT DRIVEN. I CANNOT GET THE SPARKER TO FIRE.0
I have 3 of thes heaters if anyone is interested. Motors run and has fuel pressure but not igniting0
Need parts,manual,any info available for stone silent glow heaters. I have lost the thermostat,plate,mounting for the control box on my heater.0
- 87.7K THE MAIN WALL
- 127 Chimneys & Flues
- 121 Geothermal
- 79 Pipe Deterioration
- 396 Solar
- 17 Recall Announcements
