This might sound silly but…
LiliP
LiliP Member Posts: 8
I just got a really heavy entertainment center cabinet, I live in a condo that was build in 1978 and I have radiator baseboard heaters.
I can feel the floor is warm where the pipes run through under the floor , Should I avoid to put the heavy cabinet where the floor is warm? My concern is that is it possible that the cabinet can crash the pipes underneath?
  • STEVEusaPA
    Is the floor concrete? Do you see any deflection when you placed the entertainment center?
    LiliP
  • LiliP
    I don’t see any deflection because I have granite tiles floor ,and I’m not sure if the floor base is concrete.
  • If the tiles don't crack, neither will the pipes.
    LiliPSTEVEusaPA
    pecmsg Member Posts: 6,862
    You could run a truck over the pipes and not crush them!
    LiliP
