Eternal Replacement
This Eternal water heater just died. It does both radiant heating via a Taco X-Pump Block and DHW and I'm looking for a replacement.
Rinnai has an RL75 water heater, but the warranty is void on a closed loop system. Any suggestions?
  • kcopp
    kcopp Member Posts: 4,630
    I presume this is exterior mounted?
    Can you use a regular combi boiler and build a bit of an enclosure around it to protect from weather?
    I like the IBC Superflow/ DC boiler
  • @kcopp Yes, exterior.
    IBC boiler: Reduced DHW production (3.2 gph for the IBC, 4.3 gph for the Rinnai), removing the X-Pump Block HX to install a 1°-2° piping system, 10 year warranty.
    Rinnai water heater: Better DHW production, plug-and-play, no warranty.
    The choice is .....................mine.
  • kcopp
    @Alan(CaliforniaRadiant)Forbes The SFC199 will give you 5.0 gpm. same heat out put as the SFC 125... no need for the x-block.
  • Solid_Fuel_Man
    Solid_Fuel_Man Member Posts: 2,644
    Ahhhhhh, California....where they put the boiler on the outside of the building. Crazy place over there......
