Combustion air intake pipe material for Burnham X-PV cast iron gas boiler in Massachusetts
gasboiler
Member Posts: 8
in Gas Heating
What do you suggest type of combustion intake air pipe for Burnham X-PV 85% efficiency cast iron gas boiler in Massachusetts? PVC vs steel pipe.
Can I reuse 9 year-old PVC pipe used in Buderus 95% efficiency gas boiler? Thanks.
From page 8 of the install guide...
Direct Venting – Combustion air is pulled directly from
outside using the appropriate Direct Vent Conversion
Kit shown in Table 2.2 with installer supplied PVC
or galvanized air intake piping. See Appendix A
for details on installing this boiler with a direct vent
system.1 -
I was told installing new pipe but installer reusing old PVC pipe. Should I be concern?0
its just an intake... not a problem.0
@gasboiler
Mass. has restrictions on using PVC for the flue gas outlet.
For the air intake it is fine as long as it is the right size and piped correctly0 -
Thank you all for your advice.0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
